The only thing I would add to Rusty's advice after playing with these a bit, is that I would wrap the propeller shaft splines with tape, then lube before trying to pass a seal or an Oakie over the splines if it will fit, otherwise be really careful. The splines are essentially the same diameter as the shaft so would be very easy to damage a seal or bushing. Someone recently on here had to chamfer the leading edge of the splines as his Oakie would not fit over the splines (maybe a burr).
