I have never installed an Okie bushing and, therefore, can't add much advice or input here.
Having said the above, I have never understood why one would use one instead merely pulling the old bushing and whatever is in the shaft such as a seal and install new ones of those instead.
Seems to me that the okie is more labor intense and agrevating to install and wouldn't do anymore than the original setup.
I don't know if it is necessary to install the locking pin when using an okie as it would be with an original bushing but that can't be too much trouble.
So, what is the advantage in using an okie?
Thanks,
Charlie
BTW: I have several of the original NOS replacement bushings around here as well as some okies. Don't know about the separate seals though although they shouldn't be too hard to fine from a vendor.
BTW: Go to "Jayhawker" on Youtube for a good video on installing an okie. I think it was in a 47/48 he put installed one.
