#44988 01/10/04 08:31 AM
Shocks Offline OP
I am looking for a supplier source for original style electrical wiring(1931). Can someone give me some site and/or supplier names.
Thanks, down the road...Shocks
#44989 01/10/04 11:48 AM
Sure! Click on this link: http://www.ynzyesterdaysparts.com/
laugh laugh laugh laugh
#44990 01/10/04 12:12 PM
dog,
nice site...I've been looking to replace the battery cables on the old boy and wondered if you thought the ones listed here were correct and any better than those sold by other vendors?..
ok epi
#44991 01/10/04 12:25 PM
Kepi Doodle! The positive battery cable that they sell is cloth covered like the original. The cable itself is not totally identical to the factory original, but it's the same cable that several dealers (like the Filling Station) sell.
The ground cable originally had the bow-tie embossed on the end of the cable, and I haven't seen a reproduction that does. At any rate, YnZ is an excellent place to cover your wiring needs. yipp laugh laugh laugh
#44992 01/10/04 12:29 PM
skippy,
ah-ha...thanks...
ok epi
#44993 01/10/04 12:30 PM
You bet! laugh laugh laugh laugh laugh wink
#44994 01/12/04 12:42 PM
If you want a good functional heavy gauge battery cable and you don't have to have an "original" cloth covered one go to a farm tractor dealer (John Deere, Case IH, Massey Fergerson, New Holland, etc.) or a place like Tractor Supply Company. They have 0 and 00 gauge cables with heavy duty terminals in several lengths, but they are vinyl covered.
#44995 01/12/04 12:57 PM
mrmack,
yes, that's what we have now...thanks...
ok epi
#44996 01/12/04 01:41 PM
Better yet......go to your welding supply shop and get a 0000 copper welding cable. Got one on my '51 Chevy and it works great! :eek: :eek: :eek: :eek:
#44997 01/13/04 11:42 PM
I found that under about 1/12 inches of plastic insulation that I had a 12V positive cable and of course the starting problems that go with it. I went to a local Battery/Electrical repair shop and had them build me an 00 cable that works fine and cost me $17.00.
#44998 01/14/04 01:56 AM
I went to our local Interstate Battery distributor and they took a 00 cable that was for a "big" diesel rig and cut it to the right length. It cost me around $12.00. They also had a heavy duty braided ground cable that filled the bill. laugh laugh laugh
#44999 01/14/04 02:31 PM
This thread goes to show that with Vintage Chevy people "Where there is a will there is a way!" ....and many times, many ways!
#45000 01/20/04 05:19 AM
Shocks Offline OP
Thanks for thr tip on the web site Junkdog. It was just what I needed. This VCCA suff is very very helpful. I appreciate all the responses. I hope some day I will be at a point I too can help someone out...shocks
#45001 01/20/04 10:52 AM
Glad that you found that web site useful! laugh laugh laugh laugh
#45002 01/20/04 01:19 PM
JYD
I just saw a piece of 0000 welding cable... That's Heavy Duty!! laugh laugh laugh
#45003 01/20/04 03:11 PM
Heck yes!! That's why it works go good on a 6 volt system. Only problem is...because of it's size, it takes two dudes to install the cable. One to hold it while the other dude hooks it up! ha ha! :eek: :eek: :eek: :eek:
#45004 01/20/04 05:38 PM
for those whom haven't seen 4/0 welding cable, it's made up of over 2000 fine strands of copper for flexibility and is over 3/4" diameter in section... :love:
ok epi
#45005 01/21/04 02:42 AM
0000 cable is about the right size for a set of booster cables for D-8 Bulldozers and B-29s, or a leash for Rex the wondering Dawg!
#45006 01/21/04 10:38 AM
That would be too small of a leash for this mutt! :eek: :eek: :eek:
I've had the welding cable on my '51 Chevy for years now and it works great.......especially when I have to start the car when it's hot. This larger diameter of the positive cable seems to make a big difference when starting hot. yipp
#45007 01/21/04 05:02 PM
Well JYD do you use it for battery cables and also as a tow-cable?
#45008 01/22/04 01:47 AM
hey dog,
doesn't elvira carry a 4/0 whip?..
ok epi
#45009 01/22/04 02:23 AM
Several good suggestions here for battery cable purchasing locations. Anymore suggestions for purchase or construction of a good Chevy cable or has this thread run it's course and we should close and move on.
Seems about time to leave Elvira at the movies.
Moderator
#45010 01/22/04 04:40 PM
Naw! Not Yet!
We have a lot more to learn about battery cables, we haven't even explored Dis-connects, ground cables, woven vs. stranded, brass vs. copper ...black vs red etc. etc. etc.... and ...
Elvira's potential is she Negative grounded? or positive grounded? High voltage or Ultra-high voltage, is she AC or strictly DC? is she single wired or complex wired and is she regulated or unregulated...
Think about it...
#45011 01/23/04 03:26 PM
Shocks, If you do buy a wiring harness from "ynzyesterdaysparts" or some other place, how about posting it so we know what you thought of it and the instructions. I will need a wiring harness for my '31 this summer. dance Thanks.
#45012 01/23/04 04:18 PM
Jerry, I ordered a wireing harness for my '51 a couple of years ago from a vendor (don't remember which) there was a choice of the cloth wrapped original wire or new plastic coated, Chevrolet didn't change to plastic till 53 or 54, I chose the plastic coated because I won't be showing the 51. the harness was marked as a ynzyesterdays part. It had a good instruction sheet and diagram showing the wires laid out and showing the location of each connection, I am sure a 31 would be more simple than the 51.
