Posts: 112 |
Hello, I would like to buy one of these battery minders that keep your battery on a trickle charge while not using the car. Is there a specific kind that would best for use on a 6 volt system? Also should the battery cables be removed from the battery when using the charger. Thank you.
Posts: 2,323 Likes: 6
Posts: 2,323 Likes: 6 |
I have a small one that I use on the 12 volt battery in my truck. The 6 volt battery in my 38 never allows the minder to go off charge, ie the yellow light stays on. Usually I find that occurs when the battery is about three years old but this one was like that from new.
Posts: 112 |
Old 216 hi there. Do you need to disconnect the cables from the battery when on the battery minder? I always have disconnected the cables when using a regular battery charger. Thank you.
I have a disconnect on the ground cable, I always open that when I park it. That is all I do.
Posts: 1,294 |
You do not have to disconnect the battery when using a battery tender. I put mine on during winter and never disconnect the battery.
Posts: 7 |
I have tenders on my 39 Chevy business coupe, 25 model T, and my 2004 Corvette. They are all three different brands and they all work as they should.
Posts: 1,295 Likes: 2
Posts: 1,295 Likes: 2 |
This post is from ( 2020 ) just saying .
p.k.
