I found a 7" brake booster with a dual MC with should fit under my cab. It makes a difference if you have a steer or floor shift. This setup won’t work with a steer shift due to the levers. Additionally you need a modified transmission crossmember. I ordered this set at performanceonline.com. For convenience also a remote filling set.
I also found a 1:4 remote booster suitable for my 3100 truck from a Dutch supplier, Only this is a single line booster and my goal was a dual line system.
Thanks for all your help, especially Brino, who send me a very detailed description.
@ Jianis, send me a private mail if you want the address from the Dutch supplier.
