I was able to solve the problem of the control lamp.
https://vccachat.org/ubbthreads.php...pilot-bulb-does-not-work.html#Post440398
But now there is a new phenomenon. As you can see on 0:37
the Rear Lights collapse when I switch the hazard warning. Curious is, that when I do Hazard first and then the lights, it works perfect. I don't understand this, because the light wiring doesn't go over the signal stat?
My wiring is complete new and not original. A special feature is, that the car is 6V and only the indicators, break and back lights are 12 V with this DC converter, special for Cars.
For me the 6v sparkle in the back was just too dangerous and I didn't want to change completely to 12v.
Here's the schematic, although I'm not sure if it's easy to understand?!
Attached PDF document
Greetings André
1940 Special de Luxe Sport Sedan
https://1940specialdeluxe.wordpress.com
YT Link fixed
Greetings André
