#435569 12/09/19 10:28 PM
rjp Online Content OP
OP Online Content
Has any one put a electric fuel pump inside the Vacuum so that it does not show
rjp #435572 12/09/19 10:51 PM
Never seen an electric pump inside the vacuum canister but have seen several modifications to allow use of a remote pump. Many that have tried an electric pump have had problems with too high fuel pressure or inconsistent performance with a regulator.
rjp #435574 12/09/19 11:25 PM
Most success has been with it on a switch on the dash and use it only to fill the vacuum tank.
Johnny Reb
Better yet, get the vacuum tank repaired. When repaired they work very well as intended. Electric pumps are a pain in the aXX.
devil Agrin
rjp #435591 12/10/19 09:49 AM
I agree that a good repaired vacuum tank is hard to beat. Far, far better than an electric with regulator! As long as the operator remembers that pushing down the accelerator pedal reduces vacuum and therefore amount of fuel being pumped all is good. Many of us have driven vacuum tank Chevys to the top of Pikes Peak or other high mountain roads without a problem. A few years back the VCCA Four Cylinder tour went over Teton Pass extended 10% grade. Only the gravity fed 490 had to back up to keep the fuel level in the tank above the carburetor.
OP Online Content
Does the Filling Station or some one work on them?
rjp #435632 12/10/19 10:37 PM
Rip. look in the back pages of the G&D and you might find someone who rebuilds them.
Steve
rjp #435634 12/10/19 10:43 PM
OP Online Content
Ok Thanks a bunch,
rjp #435635 12/10/19 10:48 PM
Rip. Top left corner on Pg 38 of January 2020 G&D. Rebuild service.
Steve
