Posts: 2,157 |
after having the power brake booster rebuilt and reinstalled with a new master cylinder, my brake lights aren't working...I tracked it to the brake light switch and pedal position...I cannot back the switch away enough from the pedal arm to make the brake lights come on unless the pedal is to the floor...obviously, the pedal / booster rod was set too long and moved my pedal too high (close to the switch)...does anyone know if I need to undo the hydraulic line, master cylinder, & booster to adjust this length?..after just getting the brakes operational again, I'd hate to have to go through that again...
Posts: 3,373 Likes: 40
Posts: 3,373 Likes: 40 |
You have dual posts going. You typically will get more responses if you post in the more specific forums such as this one. Most of us who view Chat regularly scan the whole list or have things set so we can easily see new threads where ever they are posted
Posts: 295 |
The power brake option included a metal bracket that bolted to the brake pedal arm. IT was an extension for the switch. Sorry, I don't have a photo.
Verne
7 members (the toolman, mario1234, R4N32, Mike McCagh, IdahoLemon, Chipper, Chev Nut),
202
guests, and
28
robots. |
Key:
Admin,
Global Mod,
Mod
Topics57,589
Posts420,582
Members17,817
