1963 impala - brake pedal height - 12/10/19 12:57 AM
after having the power brake booster rebuilt and reinstalled with a new master cylinder, my brake lights aren't working...I tracked it to the brake light switch and pedal position...I cannot back the switch away enough from the pedal arm to make the brake lights come on unless the pedal is to the floor...obviously, the pedal / booster rod was set too long and moved my pedal too high (close to the switch)...does anyone know if I need to undo the hydraulic line, master cylinder, & booster to adjust this length?..after just getting the brakes operational again, I'd hate to have to go through that again...
