Posts: 83 |
1941 coupe, 6 V system, last week the temp gage needle started moving from left side to far right side in less than a mile of driving. Car is not overheating. What do you suggest? Jerry whitfield Winston salem NC
Check the water level. It may be so low it is below the temperature bulb.
Posts: 4,024 Likes: 99
Posts: 4,024 Likes: 99 |
The temperature gauge in that car is a mechanical gauge. Nothing electrical in that circuit/ The heat in the engine causes the liquid in the bulb to convert to a gas and expand to move the needle.
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
Yes, but I think the bulb needs to be in water or some other mediem to do that. I don't think it will indicate mere steam or heat, per se. Charlie
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
In all cases (electric or mechanical) the sensor bulb needs to be submerged in liquid to operate properly. Tony
