#430300 08/26/19 10:32 PM
Hello All,
I recently got a used eagle radiator cap as a gift for my 1931 Independence. But the pieces on the underside that screw it onto the radiator are missing. Any suggestions where I might be able to find a replacement for the missing parts?
I had the same issue. Since I'm a cheap SOB I drilled the radiator cap with a 1/2" bit so that the eagle would sit flush. Then I found a nice cap screw with an allen head. Washers, and a nut on the bottom of the cap and it looks decent.
This post is guaranteed to be 100% content free!
'31 Special Sedan
Thanks Dogbreath. Do you happen to have a photo of what the fix looks like?
Two pics in the attached pdfs.
Attached PDF document
'31 Special Sedan
Thanks! These are very helpful.
