#430053 08/22/19 05:20 PM
I have a 1946 Fleetmaster that the engine was getting tired. I found a 235 out of a 54 chev . The guy was going to hot rod out his car and I bought the 235. I noticed an oil puddle under the motor and saw it was dripping out of the weep hole. Is that pretty normal or is there something wrong? Thanks Bob
Bobsmanstuff #430054 08/22/19 05:58 PM
It is quite normal and if not leaking to bad live with it. To cure requires replacing the engine rear main bearing seal.
Bobsmanstuff #430089 08/23/19 11:06 AM
Thanks Gene. I also wondered if would help a little to add some of the stop leak products on the market. Is there any harm to any part of the motor in doing so?
Bobsmanstuff #430134 08/23/19 10:35 PM
Stop leak in the cooling system may possibly work (i have had it work for me), stop leak in the oil, I doubt it will work.
Ed
Ed_Osier #430136 08/23/19 11:19 PM
Isn't there a product for transmissions that is suppose to make seals swell up to stop leaks?? Not sure if that would help on engine seal or safe to add to engine oil !!
Dick
Bobsmanstuff #430151 08/24/19 09:44 AM
Would stop leak in the cooling system work for a main bearing seal leak?
Bobsmanstuff #430152 08/24/19 09:47 AM
No it would not. That is not what I meant. I agree with Gene.
Ed
Bobsmanstuff #430157 08/24/19 11:15 AM
I see what you meant. I also agree with Gene but thought for now maybe a stop leak would slow it down instead of replacing the seal.
Bobsmanstuff #430253 08/26/19 07:51 AM
Uncle Ed,
I had the same take on your statement as Bob. Initially, that is.
You feeling okay? You may want to get the missus luv2 to proofread your posts before you hit the send button. (Check your medical dosage too. You may not be getting enough of something (Drink more corn.) Agrin
Best to you and the missus, luv2
BTW: Does your new Medicare walker have whitewalls on it? Just asking. I know, I know and apologise in advance.
41specialdeluxe #430322 08/27/19 11:44 AM
Hi Charlie, I guess I have never won any awards on my ability to correctly express might thoughts but my wife is even worse so having her proof read might not help much! No my walker doesn't have white walls but my '37 does!
Best wishes,
Ed
Ed
