Am I correct that the No.1 wire can be anywhere the distributor rotor has stopped (any of the 4 polls), as long as you hook the No.1 wire to that location and that you are at TDC (Compression) on No.1 cylinder?????
Johnny Reb
Yes, but you also want the cap clips to be orientated so that you can easily open and close them.
Here is my discussion of putting Lurch's distributor back into the block during his engine rebuild: https://vccachat.org/ubbthreads.php/topics/400583/re-resurrecting-a-28-4-banger.html#Post400583
TY again for all your help...
Johnny Reb
You've got such great records and photos of your work Dean!
