#424913 04/29/19 02:13 PM
Stubdo Offline OP
Hi all
The numbers stamp on my plate for my Chevy are
22AB 7149
Can anyone tell me anything, where it’s was manufactured etc
Stubdo #424955 04/30/19 10:20 AM
Stubdo the AB is a 1928 National and it was the 6149th vehicle produced at that plant. (1st car produced started with #1001). I don't know of any plant code that started with #22. Check that number again. #2 was Terrytown NY. #12 was Buffalo NY. and #21 was Janesville Ohio. I hope this helped.
Steve
SSG26K #424957 04/30/19 10:37 AM
Stubdo Offline OP
Hi that’s, great help thank you
Please see pic it says 22 but maybe this plate is not original
https://share.icloud.com/photos/0fcPcEiSI2vo5XuI6RRvhdG9g#Belfast,_Northern_Ireland
Stubdo #424958 04/30/19 12:28 PM
Stubdo I found your information. Your car chassie and cowl were assembled in Terrytown New York and shipped to Australia to have the body assembled. Shipped top England in 1990.
Chevrolet Motor Company
Model: NATIONAL
Car Number: 22AB6779
Engine number is R4,717,446
=22AB7149 assembled in Australia and then imported into UK in 1990 has “Late 1928” Engine # R4,973,095 and
# 348532 BLOCK BOWTIE 14 I-6-8 [September 6th 1928]
Google ... Chevrolet U.S. and Canadian production figures 1912 - 1931.
It's all there at the end of the 1928 listings.
I know this will help.
Cheers;
Steve
Steve
SSG26K #424959 04/30/19 12:38 PM
Stubdo Offline OP
Thank you so much that great information
Stubdo #425008 05/01/19 05:20 AM
Love to see a photo
Brian
lachlan31 #425017 05/01/19 10:24 AM
Stubdo Offline OP
Stubdo #425517 05/13/19 05:38 AM
Wow!! Looks beautiful, good luck with the rest, let's have some more photos of the finished product ????
Brian
Stubdo #425531 05/13/19 09:54 AM
Online Happy
Looks like it is coming together to be one beautiful Chevrolet. I have sure it will be a hit on your side of the pond. This side as well.
Stubdo #426814 06/08/19 11:37 PM
looking for info to update my 1928 chevy 4 cyl water pump. to a sealed bearing type pump. then an pressurized system.
Stubdo #426816 06/08/19 11:55 PM
Online Happy
Sorry to tell you but I don't know of a way to put sealed bearings or just seals into a 1928 water pump housing.
The Filling Station sells an early 6 cylinder water pump with seals. It required a altered water pump body (new casting) as well as slightly altered pulley (another new casting). They just couldn't find the parts to seal an original pump.
Pressurized cooling system would require a sealed pump as well replacement radiator. Don't believe just sealing off the overflow tube would be satisfactory as the original radiator was not designed for pressure. I know my radiator man puts a couple of pounds on originals to check for leaks but 7-15 psig containing hot coolant is a different situation. There are companies that make complete radiators for some older cars. They are mostly intended for rods or modified but should work if the outlets are in the proper location.
Stubdo #426825 06/09/19 11:27 AM
I saw that I was being redundant so as I couldn't delete the post I just changed it.
cabboy #426835 06/09/19 01:17 PM
There is a fellow in our regional group of the HCCA who has converted some for model Ts. Also the fellow out of Austrailia with "the red chevy" has done that on his 28. He has posted some of work he has done to it on his website.
beachbum #426879 06/10/19 10:04 AM
Hi All,
I have been running a modified 28 Chev water pump in the Red Chev since 2009 and it works like a charm. You use the original housing which is modified to take modern water pump innards, fully sealed and requires no maintenance. I have done over 7,000 miles with no issues and 3 other 28's that I recommended the pump to have had no issues also. If any one is interested let me know and I will pass on the Aussie machinist who does to conversion.
I have been running a "pressurized" cooling system, since that late 80's. and with the modified water pump I can do a 100 mile run in the heat with no water loss, and this is with a 46 year old radiator. My water level is always at the top of the radiator neck.
I fitted a gasket under the radiator cap and the overflow tube runs into an overflow tank that is not sealed. I used an overflow tank from an MG (Brass) and removed the gasket from the tank cap. Estimate the system is only just pressurized to 2-3 lbs but its enough to enable me to use modern coolant which is a no, no in the original system.
Please feel free to ask for details, and there is no point saying it wont work as the Red Chev and several other Aussie 28's are running with it.
Please see a link to my blog https://my28chev.blogspot.com/
If you scroll down there are technical postings on the left hand side including several covering the mod.
Regards
Ray
1928isgreat #426993 06/12/19 09:04 AM
Reading this I see you have the rad overflow going to a tank that is open to atmosphere with no valve or other regulating device so I believe this is an open system and should not have any pressure. Standard setup has a gasket under the cap so I don't get that as a modification? Maybe I am missing something so I will have to peruse the article you mentioned. Thanks for the info.
cabboy #427800 06/30/19 05:31 AM
Hi Cabboy,
Originally I was going to put a sealed cap on the overflow tank but held off as I was concerned that the pressure could be too much.
After a few months of experimentation and fitting the modified water pump, I was confident of the following.
1. There is sufficient pressure to expel and retract coolant to and from the radiator to the overflow tank
2. The cooling system is a sufficiently "closed" to prevent boiling
3. The cooling system is sufficiently "closed" to eliminate coolant loss
4. The cooling system is sufficiently "closed" to keep the coolant level right up in the radiator neck, just below the overflow tube.
5. The cooling system is sufficiently "closed" to be able to run modern coolant normally corrosive in an open system.
More important, after some thirty years all is well, and I regard my cooling system as good and reliable as any modern one, however in Australia we are not exposed to freezing conditions, and would not know how it would work in such conditions.
Regards
Ray
Stubdo #427802 06/30/19 07:05 AM
That's very interesting Ray, I have a similar system on my '29, I don't consider it pressurised as the overflow/expansion tank would have to be much higher than the top of the radiator to achieve that, but it does work well.
Could you explain what you mean about modern coolant being corrosive in an open system please, as I've been told that using modern coolant unpressurised leads to problematic cavitation around the pump impeller, although I don't seem to have any problems with that.
Regards Bernard
Whirrr whirrr chuff chuff de chuff........chuff......BRUMMMM!
