Posts: 107 |
My brother is replacing the control arm shafts on his 70 Chevelle SS LS6 and the ones he bought are TRW and not the offset version. I noticed the OEM in the car have bolts and the TRW are threaded ends with nuts. Was this a design change or improvement from OEM? I would think the threaded version stronger as no hole drilled into ends. I figured someone here would have info on them. Thanks
Posts: 30,699 Likes: 141
Posts: 30,699 Likes: 141 |
I would check with TRW and get their story. Sounds as if it is their new and inproved shaft and may require other parts for installation.
1 members (the toolman),
67
guests, and
24
robots. |
Key:
Admin,
Global Mod,
Mod
Topics59,069
Posts429,046
Members18,307
