Posts: 3,008 Likes: 1
Posts: 3,008 Likes: 1 |
How many and what years Nova share the same body as a 1974?
Joined VCCA June 1, 1961
Posts: 2,142 Likes: 3
Posts: 2,142 Likes: 3 |
Same basic body 1968-1974 John
John
Thanks John, See you down the back roads Jim
Posts: 305 |
Actually, the 73 and '74 Nova share the same body parts. The 68-72 look similar and share the same X-body name, but all actual parts are different. For example, '73 was also the first year for the 5 mph bumpers, which requires different fenders and quarters. The doors can interchange, but you must make modifications to mount the vent windows if desired. The '73 & '74 hood look the same except for the front lip on the '73 & '74 has a shorter front lip where the trim piece goes on.
Chris
Posts: 78 |
Chris, Nice to hear from you again! I thought that the information provided earlier was incorrect.... but far-be-it-from-me to question a National Board Member of the VCCA. John
87 Monte Carlo SS 42,000 74 Monte Carlo S 24,031 70 Monte Carlo 12,255
Posts: 58 |
John, is that really you behind that last comment? Yes, I know what you mean...... Greg
1972 Monte Carlo VCCA Senior AACA Grand National
Posts: 399 Likes: 1
Posts: 399 Likes: 1 |
Chris is right. The '73 and '74 nova doors fit on the previous year but they do not have the vent pane windows of the '68-72. Some part do interchange but I would stick to the two years Jim. Why do you ask? What's up?
Guys I would just like to clarify myself as far as the information I provided, it was based on Standard Catalog of Chevrolet 1912-1998 printed by Krause, edited by Ron Kowalke. When Jim posted the question I was thumbing through the book looking up something else. The book stated that the 1975 lineup was the first major body change in 8 years. I did not think Jim was looking for specific part interchanges with his question. I look at these year Novas as a platform similar to the Corvairs 1960-1964, as in that case the 1960 is a stand alone unit, but yet is still considered to be on the same platform as the other years. They also I have learned have very little parts interchanges. My mistake and my error for offering printed information that I presumed to be correct. John
John
I should have been more to the point. I should have asked about the padded dash and the instrument panel. I have an instrument panel with a tachometer in it. Probably from a SS. Jim
Posts: 305 |
Jim
The tach dash was used on a car with the optional gauge package. In 1972, this option was available on any V-8 powered Nova. If my memory is correct, the tach dash does not have a gas gauge in it. The gas gauge was in the console gauges. FYI - the later model Nova's (75-78 I think)with the gauge package used an volt gauge rather than the amp gauge. I found this out when I purchased the wrong unit.
Take Care,
Chris
Thanks for your help Chris. See you down the back roads. Jim
