Posts: 107 |
1965 Chevelle, Several years ago I picked up an electric trumpet horn off of a 65 Chevelle it was mounted on the inner fender and looked to be a factory installation does any one have any information on this horn. Thank you
Larry
Posts: 865 |
Larry, My 1965 accessories manual lists a Tri-Volume horn available for Chevrolet, Chevelle & Chevy II, option no. U-03, part no. 986265. I have a 1964 accessory installation manual but it is at the shop and I will check it when I can, it might be the same as 1965.
DANDYD
Posts: 107 |
Thank you for the information, I am looking forward to here what you find. Larry :)
Larry
Posts: 865 |
Larry, The accessory manual I have is a 1963, not 1964. Sorry my mistake. I will keep searching.
DANDYD
Posts: 107 |
Thank you guys, The horn that I have I took off a 65 Chevelle at the local pick a part and it was bolted on the inner fender and it is painted black, I just wanted to make sure that it was correct.
Larry
Posts: 107 |
SkIP, That is what I have, Thanks
Larry
