Posts: 82 |
I noticed that I have a weak leaf spring in the back on the drivers side of my Roadster. The drivers side is lower in the back than the passenger side. Not to mention the rear looks kind of low in the back overall. I think I read on Bill Barker's "1931Chevrolet.com" website that different models had different leaf spring setups. For example, Roadsters had 5 leaf leaf springs, coupes had 6 and sedans had 7. Can anyone confirm this? I would like to correct my weak rear...lol!
1931 Deluxe Sport Roadster 1931 Sport Coupe
My 1935 parts book shows 6 leaves for the roadster and there is no 5 leaf listed.
Posts: 82 |
I unfortunately do not have one...
Posts: 269 |
My 31 Roadster has 6. I hope that helps.
31 Chevy Roadster 64 Corvette 76 Corvette 77 Grand Prix
Posts: 82 |
My 31 Roadster has 6. I hope that helps. Thanks, Is yours an early or late production '31? I will have to check mine.
If the roadster was available with and without a rumble seat the number of leaves could make a difference.
If the roadster was available with and without a rumble seat the number of leaves could make a difference. The standard roadster had a trunk and the sport roadster had a rumble seat.
Posts: 269 |
My Sport Roadster was early November 15, 1930.
Then it is possible that the rumble seat model had more leaves in the springs.
Then it is possible that the rumble seat model had more leaves in the springs The rumble seat model used 7 leaf rear springs because of the two extra passengers.
Posts: 82 |
Then it is possible that the rumble seat model had more leaves in the springs The rumble seat model used 7 leaf rear springs because of the two extra passengers.  This is what I found on my car. I have 7 leaves in my leaf springs. But I still have a weak spring on the drivers side. I guess I will have to keep my eyes open for a 7 spring matched pair.
Posts: 82 |
