Pancho Offline OP
if anyone can help me with this issue it would be greatly appreciated. i am trying to remove the entire dash for sand, prime and paint. i got the glove box and instrument cluster gauges off, so what is next. i see not bolts that hold the dash in place. can someone help.
Wilwood Engineering1955-1957
Pancho
I am not familiar with the 63 models but there is a possibilty the dash frame is a welded in part of the structure. In which case sand and paint it as well.
Pancho,
The main dash frame is welded to the cowl. The "bolts" you see are the support rods. The easiest way to do what you want to do is to remove the windshield and work the dash from the outside. Also remember that the paint should have a satin finish, a gloss finish will make it almost impossible to drive on a sunny day with the reflection
John
John
1954 Belair Sport Coupe
1977 Monza Mirage 305 4 Speed
1988 Celebrity Wagon
Pancho Offline OP
tony and john, thanks for the info. is the windshield hard to remove? what kind of paint should i use to get the "satin finish"?
Pancho, The hardest part is removing the trim around the windshield without bending it. I would just cut the gasket and buy a new one for $75. As far as the paint I know I have the numbers somewhere, I will look tonight. What color?
John
John
Pancho
John beat me to the comment. As for color I would check factory specs but failing that I would think they are body color or matt black.
Pancho Offline OP
john the color i am looking for is saddle. i dont know if i can get the exact color, but anything very close would be helpful. oh and as far as the dash. i took off the windshield. yeah the trim was tricky but i managed. i did not have to cut the gasket, cuz apparently the windshield had been replaced and came off smoothly.
1963 Interior Colors
Black
Dupont 44
R-M 400
Ditzler DL9292
Med. Saddle
Dupont 95355
R-M 62C82
Ditzler DL22298
Dark Blue
Dupont 96315
R-M 63V36
Ditzler DL12740
Red
Dupont 2967
R-M 59C51
Ditzler DL71357
Med Saddle*
Dupont 95243
R-M 62C87
Ditzler DL22299
* used on rear window garnish and halo panels only
Good luck,
John
John
Pancho Offline OP
john, thanks for the info. i greatly appreciated. my only worry is if i will be able to find it at a local auto store. thanks again.
try the guy in North Carolina he always is running ads in Hemmings
john
John
