#400606 12/27/17 05:41 PM
babydog Offline OP
I am looking for replacement bulbs for my guide 2025 sealed beam fog lights they are 5 inch 6 volt are the sealed beams
rebuildable or are replacements offered
thanks
Bob B
For better coverage, you might want to post the above in the "Parts Wanted" forum.
You will need a replacement sealed beam and not a bulb. The thing that looks like a bulb is built into the sealed beam and vacuum sealed. This sealed beam was used from 1949-1952 passenger fog lights and 1949-1954 truck sealed beams.
The Chevrolet part number is 451651. There is probably a Guide number for it also but I can not find one.
That sealed beam was used for most GM cars back then.
I could use one also.
babydog Offline OP
ok thanks for the info
Bob B
I have a number of NOS Westinghouse 4012A bulbs. If you are interested let me know. 4012A spec.
They look like this.
Tiny #400643 12/28/17 08:55 AM
I believe the wrong synapse fired. I think they're Wagner bulbs. I found a stockpile just after they stopped making them. I sold some on ebay. I have a few left if you're interested.
Tiny #400861 12/31/17 08:02 AM
babydog Offline OP
the ones are sealed up in a metal jacket have guide 5 inch
fog lite wrote on them on the bottom of the glass and the word
GUIDE in the center of the glass no numbers
thanks
Bob B
These are sealed beam bulbs. Do you have a photo of your bulbs? I've never seen one in a sealed metal jacket.
Tiny #400864 12/31/17 10:26 AM
The Guide 2025 sealed beam was a metal back built-in bulb unit and different from what you have. Also have a clear lens with one exception.
Thanks Gene, bet those babies are hard to find.
