#390073 06/01/17 04:33 PM
Jump88 Offline OP
I've pulled the fuel tank out for a good cleaning and found that the fuel line outlet from the tank doesn't have a fuel pick up tube or line. This is on a stock 1930. With the way it currently is, I would always have to have a full tank. What is the correct fix?
Thanks, Bob
There has to be a dip tube in the tank otherwise the fuel pump will not be able to suck the gas out of the tank. Are you sure that the tube hasn't broken loose and laying in the bottom of the tank?
Jump88 Offline OP
I looked for a tube, pipe or ? The only thing in the tank was a hand carved stick with notches, fuel gauge?
The dip tube is a solid tube that goes down the side of the tank from the outlet and then it runs across the bottom of the tank. Without the dip tube you won't get any gas up to the fuel pump.
The sending unit for the fuel gauge is not a hand carved stick with notches.
You're killing me Dawg!
All the Best,
Chip
"It's wise to choose a SIX"
Jump88 Offline OP
I get it, I just can't find a part listing for it. Don't know what it looks like or what it's made of?
The dip tube is part of the gas tank and it is not listed separately.
I have this same issue with the missing tube. Car always needs to be full to run more than 15 minutes. How can I get this tube
You will have to make the tube and then have it installed in the gas tank.
Is there any diagram or a picture. What is it made of. Fuel line
The dip tube is a steel line like the one used for the fuel line that runs from the gas tank to the fuel pump. You can buy the steel line of the correct diameter by the foot from your local auto parts store like NAPA.
The fuel line runs down the inside wall of the tank and then part way across the bottom of the tank. You will probably need a sheet metal man to install the line for you.
Dwag
Not quite sure where the tube starts and ends
Gene
The dip tube is connected to the inside wall of the tank where the fuel line outlet is. The dip tube then goes down the wall of the tank on the inside and then runs part way across the bottom of the tank.
i just stripped and painted my tank and did all new gaskets, i will see IF i can get pictures inside for you all.
ok, had to use mirror to get some pictures, and also threw together a quick sketch of HOW my tube is in my tank. there is a small wire that is wrapped around end of tube and tack welded to the bottom of tank to hold the end of the tube down.
1929 Fuel Tank Tube Sketch
Green is Fuel Tank
Cyan is Tube to feed Fuel
Blue is wire tacked to tank around tube
Back of Fitting on tank for Tube
Feeder Tube inside Tank
Wire Around Tube on Bottom of Tank
Pictures are not the best, large mirror would not fit in the opening, and the go pro was to big to get in as well. i do not have a bore scope camera either ;/
hopefully this will get the concept down !!
Ok, got the concept. The fuel is sucked thru this pipe to the fuel pump instead of from the tank directly. Thanks very much for the help
Genem
