The following may not answer the original poster's question, but it helps set the record straight regarding Corvettes:
" Each Corvette was assigned a serial number, which later became known as the vehicle identification number (VIN). On 1953-'59 Corvettes the serial number plate moved around slightly, but it was always on the front part of the left door post and was retained by two phillips head screws. In 1960 the serial number plate was welded to the steering column under the hood just below and slightly forward of the brake master cylinder. The relocation of the serial number plate from the door post to the steering column occurred on AIM date 11-24-59..."
From
The Complete Corvette Restoration & Technical Guide- Vol. 1 1953-1962 , by Noland Adams, page 255.
