TO FIND A vcca TECH , YOU NEED TO JOIN THE VCCA CLUB, NOT THIS, UNLESS SOMEBODY HERE CAN ANSWER YOUR QUESTIONS. ????????
BEST TO REMOVE PIECES ONE AT A TIME, BUY A 9--12" WOOD BANDSAW AND COPY THAT PIECE. THEN REMOVE AND MOVE ONTO ANOTHER PIECE.
YOU MAY ALSO NEED A WOOD PLANER MACHINE , DEFINATELY A HAND PLANER CAN BE ELECTRIC , AND ALSO A HAND BELT SANDER THAT DOES 3 X 24 BELTS. DON'T FORGET A NEW WOOD CHISEL SET, YOU WILL USE THEM , ITS A BIG JOB.
NORTHERN WHITE ASH IS AN EXCELLENT EASY WORKING WOOD AND CAN BE HAD FROM YOUR LOCAL LUMBER SUPPLY SHOP ALONG WITH OTHER.
MIKE LYNCH..................
