Posts: 8 |
I am having trouble finding the trans oil capacity ON my 27 Capital AA. Thanks
Posts: 148 |
Hi, There is a level plug in the right side of your gear box, fill to that level with the car on a level surface.
Brian
Posts: 8 |
I know that, but i need to know how much to buy,ie: one pint, two pints etc. I am changing the oil to the correct 600W.
Posts: 3,511 Likes: 48
Posts: 3,511 Likes: 48 |
Hi RBrown,
Welcome to the web site! This is THE place for hobknobbing with vintage Chevy folks.
I don't know the exact answer to your question, but here is my take on buying the 600W oil.
Considering that the transmission, the u-joint, and the differential all use 600W, you are looking at roughly 1+ gallon to take care of all three.
Instead of paying a lot per quart, I opted to buy a 5 gallon bucket of it from a local industrial oil dealer. Granted, I have two vehicles so I use roughly 2 gallons per year. I think going this route is cheaper than buying the Mobil 600W by the quart.
Posts: 814 Likes: 1
Posts: 814 Likes: 1 |
RBrown back in the 1920's gear oil wasn't measured out in pints or quarts. It was in pounds. For a 1927 Chevy transmission it was 2.5 pounds of 600-W gear oil & the differential took 4 pounds of 600-W gear oil. Together it would be about 1 gallon. Engine oil & coolant were measured in quarts.
In the later years it was refered to in both pounds and pints and they were the same. To refill a transmssion buy a common quart and that sould be enough with a small amount left over for future use.
Posts: 8 |
Thanks, that is what i needed to know as that i am only changing the transmission, and most of the vendors are selling it by the quart. much appreciated Roger
