Posts: 687 Likes: 3
Posts: 687 Likes: 3 |
I remember someone asking how to remove the emblem, but I couldn't find the thread. Could someone refresh me on how to do this. Thanks
Posts: 687 Likes: 3
Thanks JD. I was hoping it wasn't threaded.
Posts: 151 |
You can pop it out with a socket the same size and rubber hammer.
kerry j camp
Posts: 687 Likes: 3
Thanks, it came out fine. I'll be sending the shell out for chrome plating. I'm not sure if they will want the steel spreader removed from the bottom before plating. I like the look of the rivets being plated so I am wondering if it can be done without disassembling.
Posts: 687 Likes: 3
That makes sense. They don't want to bother with dissimilar metals.
I use stainless steel rivets similar to the original ones. Takes a air hammer, rivet setting tools and patience but produces an assembly looking like the original.
Yes the rivet head screws look the same from the outside but not even close on the other side. Same on the hood handles and hooks that attach to the hood sides. As they say close but no cigar.
The male rivet head screws on the inside of the radiator shell support bracket are in a place where they will probably not be seen. I would much rather use those at that location instead of pounding on a very expensive, freshly chromed radiator shell to put in real rivets. Too much chance of possibly denting the shell or cracking the new plating. I agree on the hood handles and hooks and I would not use the rivet head screws in those locations, but in a place like the radiator shell support bracket where they won't be seen is a different story.
