I need to replace 216 engine in my 40 coupe due to blown engine. The service manual is somewhat vague about removing the front end as a single unit before swapping engines
Do I remove both outer and inner fenders at the same time? Also sounds like radiator stays in place and not required to be removed separately. Is this true.
I don'the want to unbolt more than necessary, but am concerned that the total weight of the front clip might be too much for two persons to lift..
Good advice is always welcome..
