#365082 03/24/16 05:56 PM
low36 Offline OP
I own a 36 1.5 ton and I wonder if there is any information on how many still exist. I would not think they would be very rare but I have not seen very many.
low36 #365095 03/24/16 09:51 PM
I have one and see them fairly often on eBay. They are usually rough and being promoted as rat rod material.
I bought mine on eBay in about 2006. It came from west central Kansas and is good and solid.
You can see my truck in a thread farther down in this section of chat. Look for "1936 low roof semi truck" or something similar. My Son, Sam posted lots of pictures since starting the thread a few years ago. Let me know if I can help in any way.
35Mike #365117 03/25/16 11:24 AM
Here are a few listed on the Stovebolt web site.
http://www.stovebolt.com/gallery/gallery%2036%2040.html
Scroll down to the medium & heavy trucks.
low36 #365184 03/26/16 10:46 AM
Sorry, I can't answer your question, but I have to you a request. (A request and to other owners 1,5 1935/1936 too). Look at the picture. Perhaps there are photos of this area - interestingly as support of a shaft is attached to a frame. Or perhaps you will be able to take such photos? Many thanks.
Support - ?
35Mike #365194 03/26/16 01:35 PM
low36 Offline OP
Mike I have seen the pictures of your truck. What a great job you have done! My 36 is a 103 wheel base so it looks a lot like yours. It was owned by my grandfather and was used as a wrecker.
When I pulled one of the rear hubs and found that the round plate that covers the inside grease seal is missing. I have checked the online sites with no. Any ideas on finding one? Thank you for your reply.
I em new to forums so I hope this the correct way to post.
low36 #365257 03/27/16 10:12 PM
103" wheelbase?? are you sure? My truck was originally 157". I shortened it to 131". These are the only two original wheelbase choices.
Currently my Cab to axle distance is about 4 to 4-1/2 feet. If your truck is 28" shorter than mine, your rear axle is only 2 to 2 1/2 feet from the cab. Is this true?
I have some grease deflectors but they have no part number tags. I don't remember what the ones on my truck looked like. If you can get me a photo or description, I will see if they match. I also have two rear ends for parts so I can fix you up, one way or another. The deflector is only for '36 1-1/2 ton.
Call me any time.
573 592 1991 days
573 864 6539 other
35Mike #365438 03/30/16 09:54 AM
low36 Offline OP
Mike my typing mistake, 130" wheel base. I will call you regarding the deflector. Many thanks!
35Mike #365462 03/30/16 02:29 PM
35Mike, I have found your photos "1936 low roof semi truck". They have very much helped, I have seen that area which interested me.
Thanks once again!
