Cables that are easy to remove can be disassembled and lightly sanded to remove all the rust from the wire. Dip the outer shell in some used motor oil and then let drip dry and then clean with a cloth. Reassemble and reinstall. Makes a world of difference. If you can get to the controls in the car, some heavy oil will improve the operation.
