Posts: 95 |
Ciao. I'm sorry for my bad english but I'm Italian. I've got a Chevrolet AC of 1929 and I'm restoring it. I'd like to know the spark plug's size and temperature. My chevy's spark plug is 18 mm diameter and 13 mm long but cilinder's hole is 19 mm long. Are my spark plug too short? I hope I've been clear. Thanks for the answers and saluti dall'Italia.
Welcome to Chevy Chatter! The correct modern spark plugs for your 1929 are AC-C87. The plugs are 18MM.
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
The 13 MM sounds about right. I have C86 plugs in my 32 and that is 12.87 MM .
Posts: 4,374 Likes: 30
Posts: 4,374 Likes: 30 |
Running the recommended AC-C87 plugs in mine
Posts: 2,262 Likes: 6
Posts: 2,262 Likes: 6 |
Welcome to Chevy Chatter! The correct modern spark plugs for your 1929 are AC-C87. The plugs are 18MM.  You can buy them from the Filling Station here in the USA online. Here is the link: www.fillingstation.comAll the Best, Chip
"It's wise to choose a SIX"
yeah, i picked mine up at O'Reillys
Posts: 95 |
Hi! Thank you all. Ok 18 mm diameter. But I did not undestend if there are problems putting a spark plug 12,7 mm long, in a cilinder hole 20 mm long. Thanks again. In Italy there is nobody to ask for it. Saluti dall'Italia.
Posts: 95 |
Thank you again. Saluti dall'Italia.
Posts: 95 |
I unscrewed old spark plugs. The second and the third are blighted. The others are ok. It is possible that the cylinder head gasket is burned?
I have a picture on my PC but I can not put it on post
Ciao Alfredo --
è necessario effettuare alcuni test aggiuntivi. Il più importante è per testare la pressione di compressione di ciascun cilindro utilizzando la prova speciale indicatore. Se i cilindri numero due e tre hanno significativamente minore della pressione di compressione rispetto agli altri cilindri, le cause più probabili sono:
-- gravemente usurata o masterizzati di aspirazione o di valvole di scarico dei cilindri con una bassa pressione di compressione, o -- guasti della guarnizione della testata dei cilindri con una bassa pressione di compressione. -- i pistoni danneggiati o gli anelli in cilindri con bassa pressione di compressione.
Se tutti i cilindri hanno quasi la stessa pressione di compressione, poi ci possono essere alcune altre ragioni -- ma si dovrebbe provare il controllo di compressione prima. È possibile acquistare il tester di compressione tramite internet o nei negozi che vendono parti di automobili in Italia.
Buona fortuna a trovare il tuo problema. Cercheremo di aiutarvi se possiamo.
Tutti i migliori,
Chip
Hello Alfredo --
You should make some additional tests. The most important one is to test the compression pressure of each cylinder using the special test gauge. If cylinders number two and three have significantly lower compression pressure than the other cylinders, the most likely causes are:
-- Badly worn or burned intake or exhaust valves in the cylinders with low compression pressure, or -- failed head gasket in the cylinders with low compression pressure. -- Damaged pistons or rings in the cylinders with low compression pressure.
If all cylinders have nearly the same compression pressure, then there may be some other reasons -- but you should try the compression check first. You can buy the compression tester via the internet or in the stores that sell car parts in Italy.
Good luck with finding your problem. We will try to help you if we can.
All the Best,
Chip
Posts: 95 |
Thank you. I'll try test the compression pressure of each cylinder. I will keep you informed. Saluti dall'Italia.
Posts: 42 |
Posts: 17 |
alfredo. I have atransmision from a 1930 chevy that's partialy disassembled. if you count the teeth and let ne know I would be willing to sell it to you and ship it.
farnerbarrett
I don't see any major problems with the spark plugs. I suspect that the "corrosion" is due to moisture getting to the plugs when one of the valves to that cylinder was open to the air and moisture could enter over a long time. It doesn't look like there is a massive amount of corrosion like might be caused by a cracked head or leaky head gasket. It appears that the carburetor is running a bit rich (too much gas to air ratio). Could also be plugs are not proper heat range. Or can be that the engine doesn't run long enough to burn off the carbon produced with a cold start. It is normal for cylinders 1 & 6 to run a little lean, 2 & 5 to be about right and 3 & 4 to be a little rich. That is due to the passage length between the carburetor and carburetor (longer distance = more resistance = less flow = less gas). If a cylinder has weak oil rings it might use more oil and therefore have more carbon build up on the spark plug.
Posts: 95 |
My best compliments Chipper: You did an perfect analysis. Thank you very much.
Thanks also you Barretfarm: I'm going to count the teeth and then I will let you know.
Saluti dall'Italia
Posts: 95 |
Hi Barrett. I can't count the gear's teeth. I ask you and at Chipper if you know if transmission of '29 is same of '31.
Barrett, can you edit some picture of your transmission? What does it mean: partialy disassembled? Have you all the pieces (gears and shafts)?
Buona notte dall'Italia
Some of the parts are the same in a 1929 and 1931 transmission. The spline number on the center shafts are different and therefore so are the gears.
Posts: 17 |
alfredo. the transmission I have has no cover or input shaft. the number on the box is 590391. the gear has 20 teeth and slides on a splined shaft wich I also have I hate to pull the gear out if it wont fit. thanks
I don't know how we got so far away from 29 spark plugs. Please drift back in line.
