There is no recommended sealant for the windshield or the rear window using the LYNN STEELE rubber.
Only thing you have to pay attention to is making the BUTT JOINT real tight when the rubber comes together. That is where I would want an adhesive to butt the pieces together. Otherwise you will get a leak.
I used 3M #80010 Super Weather strip Adhesive. Masking tape the area off real good you do not want this on the paint as it really sticks. Use a toothpick to coat both surfaces to butt together and after its dry use the toothpick again to fill any opening in the butt joint. JUST opened tube.!!!
Problem with this part number is that the liquid cement is yellow. I would talk to LYNN STEELE RUBBER for a black joint sealant.
I noticed reading the lynn steele online catalogue they now have a special rubber that goes into the 1933--1935 chevys side window metal channel that will seal at the top stopping the water from getting down inside your wood laden doors and starting rot and rust.
mike lynch
