#362060 02/09/16 10:40 PM
duhen Offline OP
Hi. My Roadster 1932's engine is getting too hot when I'm moving. [ 185 degrees without thermostat ].
They radiator seems to be good, but it's a model with a grille to looks like an honeycomb.
The cost for a new honeycomb core from Filling Station is 1195$ us [ +- 1700$ ca ] it's a lot of money.
I've talked to a guy who fix radiators and it dont looks easy to install a modern CORE on my original TANKS.
Anyone already gone through that?
duhen #362065 02/09/16 11:11 PM
I have had several modern cores installed in '28 and '31 radiators. Use "V" cell if I consider the original might be a bit limited or plan to use the vehicle in parades. Otherwise use "fin & tube" or "tubular" as they are less cost. Recently had one recored using a honeycomb made by a fella in PA. Cells are smaller than original. Haven't tested it yet. Core cost was in the $ 600 range. He can make two per week. Sorry I don't have the name as the local radiator shop orders the cores.
duhen #362081 02/10/16 04:43 AM
I too have had several new cores done with the old tanks, no problem if your man knows his job.
Brian
Chipper #362088 02/10/16 08:16 AM
duhen Offline OP
Could you explain to me what is a "v" cell?
duhen #362093 02/10/16 09:39 AM
It is called a "V" cell because the cells are alternating "V" shaped. When you look at it the "Vs" are on their side.
