#356880 11/28/15 12:34 AM
What color should the brace under the front of the front fenders be. My fenders are black and should the bottom of the fenders be gloss or semi gloss
oldchevy30 #356885 11/28/15 12:53 AM
Black. Everything was dipped back then...Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
oldchevy30 #356887 11/28/15 02:28 AM
"Semi" gloss was not used back then. Under your fenders should be a gloss but not a high gloss.
oldchevy30 #356895 11/28/15 09:55 AM
It is technically true that semi-gloss didn't exist. However the most accurate modern paint would be semi-gloss or high gloss lightly dulled with steel wool or very fine sand paper. Some inexpensive, lower quality gloss paints will also produce the lower DOI surface you are trying to duplicate. Because the chassis sheet metal parts (fenders, splash aprons, running boards, gas tank covers) were originally dipped the surface would have been smooth (without orange peel) and also have occasional runs or drips.
