How can I replace this? Is it welded? I've had to drill out the old screws and now it must become new.
[Linked Image from 1940specialdeluxe.files.wordpress.com]
Greetings André
1940 Special de Luxe Sport Sedan
https://1940specialdeluxe.wordpress.com
Russell #38868
'48 4 door Fleetline
Thanks,but how do i fix them? Think, i Need the metall cover over the bolts and on the other way that doesn´t fit, because i have screws from inside?!
Another Problem is the Rubber, i´m not happy with the fitting.
The rubber curl in the rounding.
Also I´ts a little bit different to the original, because the knurl is finer.
original
Repro
Whats this for a Rubber? Was in the Set with the Windshield Rubber. Can´t find a place for it
Greetings André
rubber
Do you have a body manual. The link is to '41 but the same as far as the glass goes, pretty sure.
The metal center piece has to be cut out and new welded in. Only way I think.
When you bought the weather stripping, it did not come with instructions?
The rubber in the bottom picture is call "pinch weld". It is what holds the chrome.
Russell #38868
Andre
Russel is correct in that you will have to weld the new center strip in. You are German (note my last name, really Dietrich) so I don't have to tell you to meaaure carefully or your windshield gasket and interior center piece trime will not fit properly (screw holes won't line up).
Your windshield gasket appears to be the wrong type. Your reveal molding (chrome) is mounted directyl to the pinch weld and you only need 1 groove to mount the glass. I have had my '40 for over 50 years and have put a new gasket on the windshield twice and both times the gasket had only a single groove for the glass and no lip to cover the pinch weld. The gasket appears to be for a Master Deluxe or Master 85 which do not have the trim on the pinch weld. On the '40 Special Deluxe the only thing that holds the windshield in is the bedding caulking/sealant and windshield interior trim.
Andre
Checkout Stovebolt/Tech Tips/Windows for some excellent docs on all your window sealing problems.
Cheers
Thanks for the Tipps.Oh yes,the manual. I've searched for details, but totally forgotten my manual.
The gasket is the right one, for SDL with chrome! I've checked stovebolt Tipps, but could't find something similar to my window.
Seems so that under my chrome isn't any gasket. Better i do not touch this! Will post a picture from the chrome later
By the way the gasket was from obsolete, but they are no longer on business.But they answered my mail. I can fix the curling rubber with a heat gun or laying in the sun -we will see!
Greetings André
Looking at the top picture it appears the chrome reveal molding is glued on with silicone? Oh my! I don't know how you will cut out the divider and weld in the replacement without removing the chrome.
Russell #38868
By the way the gasket was from obsolete, but they are no longer on (in) business.
After 47 years in business, Obsolete Chevrolet Parts of Nashville, Georgia was recently acquired by Jim Carter Truck Parts.
@ russell - sh.., thats a good question hello2
Greetings André
Yeah, did it. Remove the Chrome without damaging. Pushed it down at the Top of the Window with a Plastic Wedge and than i lever it piece for piece.
Unfortunately a little bit rusty
The little gasket fits good, but doesn´t make any sense. The drawing in the manual shows only seal, no gasket
The groove in the old Windshield gasket is from the chrome, think i have to do the ribbed side from the new one to the inside.
and why is the one wiper shorter than the other one?
Greetings André
I suggest you clean up all the rusty metal around the windshield and then paint it with a good rust covering primer. If you don't, you will be removing it and re-doing the job.
Agrin devil
Thats the Plan
Greetings André
It does appear you are correct about the small rubber. Follow your manual. Your chrome may be too small to fit over the rubber anyway.
Clean off the rust and a good coat of rust preventive paint like you plan.
May be a few days away, but when the times gets here, I highly recommend this to install the glass and bedding the whole works.
sealer
Russell #38868
The small rubber is for a later model. It was used on 1948 models and probably also '47. It's only purpose was to hold the stainless moldings in place.
Scroll down to Mr. Goodwrench, then body-sheet metal. See what Mike has done.
Russell #38868
Sorry, I have continued to write about this topic in Mike´s Thread here https://vccachat.org/ubbthreads.php/topics/385459/re-41-vertical-windshield-divider.html#Post385459 and will continue to describe my progress there
Greetings André
Andre
Been away for awhile. Three things. 1. Figure 15 above does not apply to the 1940 Special Deluxe. 2. I had to drill out the screws in my center bar but I had enough "meat" left that I was able to JB weld (glue) nuts in place. Use the interior center bar for alignment. 3. You have a Master 85 windshield gasket or wrong gasket rather than a '40 Special Deluxe gasket. The '40 Special Deluxe gasket does not hook over the pinch weld but butts against the inside of the pinch weld. Be sure to reinstall the windshield stainless trim before you install the windshield as the correct windshield gasket butts up against the stainless trim. When you install the windshield, lay a fat bead of sealant just below the stainless trim on the inside. That way enough sealant will squeeze up and seal between the trim and the gasket and prevent water from seeping in between the gasket and trim.
One of the windshield wiper arms is the wrong part.Both should be the same length.
Andre
Go to Steelerubber.com PN 60-0185-50 for a good description and price.
Hello Mike,
after all, I think Figure 15 on the left is for the 1940 Special Deluxe, especially since it is the same picture as in the Steel Rubber Discription. Also i think the big gasket is the right one, but the small "S" one is wrong and not for SDL. I mean that was a one fits all package?!
When i bought this i had a long chat with Teresa Newborn from Obschevy.com. She told me
If your car only has windshield moulding down the center bar you would use B01000 gasket $55.00. Some of the deluxe cars had additional moulding around the windshield and use the B01000C or the deluxe gasket. The windshield gasket includes the center bar and the rubber around the glass, so you don't need any additional seals.
Both the standard and the deluxe gasket basically look the same with the center bar made in the middle. All cars had the chrome down the center bar but only the deluxe cars had chrome around the windshield.............Do you want the B01000C or the B01000 windshield gasket?
I bought the B01000C / "Windshield gasket with slot for chrome"
As next step i would install the chrome moulding as described in Mikes Post
Greetings André
Andre
If your Special Deluxe windshield trim is like mine and from your other post it looks like it is. The only way to install it is over the pinch weld. It will not install in the slot in the gasket. The gasket with the slot for chrome is for later year model cars. I put a new gasket in mine in 1971 and again in 1999 and both times I used a gasket that butts up against the pinch weld from the inside and does not hook over the pinch weld. You may use the gasket you have but you will not be able to install the chrome trim.
