#352128 09/20/15 07:32 PM
Twigs Offline OP
Trying to find out..if the Water Pump Pulley is all one piece of the water pump?..The Pulley on my 39 is all very loose and wobbly...is it time for a new water pump assy..part# 838903?
Thank you,
Twigs
1939 Chevrolet Master Deluxe 4dr sedan
VCCA# 50190
Twigs #352129 09/20/15 07:59 PM
The pulley is separate from the water pump.
Twigs Offline OP
Do you have to pull the Rad out to replace the Water pump Assy
Thank you,
Twigs
VCCA# 50190
Twigs #352131 09/20/15 08:28 PM
To make it easier, it helps greatly!
Twigs Offline OP
thanks..I thought so..Yuck...
Thank you,
Twigs
VCCA# 50190
Twigs #352170 09/21/15 07:25 AM
I have changed mine ( 1939 Master Deluxe)with the rad installed. It is close but can be done. Taking the rad out requires hood removal which is not an easy one man job.
Good luck.
I'm with Dave on this one. It can be done with much less hassle than pulling the hood. Just be prepared for the possibility of losing a bit of skin to the radiator if you're not careful.
Tiny #352177 09/21/15 08:33 AM
If the pulley is loose or water pump bearing is bad making it appear to be looosose you will need a new water pump and it will come with the pulley pressed on. The water pump is not difficult to replace on a 1939 without removing hood, etc. Just unbolt the fan blade first.
Twigs #352185 09/21/15 09:36 AM
It is very unusual for the pulley to be loose or wobbly unless the bearings are gone on the pump. When working in the area of the pump to prevent skinned knuckles put a thin sheet of cardboard up against the radiator. It will also help to prevent damage to the radiator core.
Twigs Offline OP
When installing the new water pump..do I need any gasket sealant on the new gasket?
Thank you,
Twigs
VCCA# 50190
Twigs Offline OP
The pulley is pretty loose..it just flops back and forth..I just install a rebuilt generator..is it possible I had the belt to tight to make the pulley break like this..it sure did not seem to tight..this water pump is at least 35+ years old..
Do I need to drain the water out of the Rad to replace the water pump?
Thank you,
Twigs
VCCA# 50190
Twigs #352254 09/21/15 10:49 PM
Reply-
No and yes.
Twigs #352255 09/21/15 10:50 PM
Twigs Offline OP
Is there someway to straighten out some the comb on the Rad where the fan blade had rubbed again the Rad...Can it be done without taking out the Rad?
Thank you,
Twigs
VCCA# 50190
Twigs Offline OP
Originally Posted by Chev Nut
Reply-
No and yes.
Thanks Gene..
Got and answer on the Comb question
Thank you,
Twigs
VCCA# 50190
