Posts: 184 |
Does anyone know a source for 5/8" wide fabric hood lace with a hole down the middle for a wire?
The stuff from Jim Carter is too narrow and is not hollow in the center. Chevs of the 40's has the same stuff but with a wire sewn on the back, not threaded down the middle - and is still too narrow. The Filling Station appeared to have the right stuff but when I called he said they had none and he didn't know when or if they'd ever get any more in the future.
From where are you folks getting yours?
Posts: 3,163 |
That's a different answer than I got from Steve, owner of the filling station....unless something has changed....Joe
Posts: 184 |
Well he definitely said that he had no idea when they would be back in stock. The "if" part was my interpretation of his tone - perhaps I was mistaken.
Posts: 775 |
Try here, AAA, they are hit or miss on what they have in stock but worth a try. Brian
Posts: 7,046 Likes: 107
Posts: 7,046 Likes: 107 |
Can't tell if it's wired or not or the size but it's worth the call. I don't see any wired here <CLICK> . I didn't use wired on my '38 & you can't tell the difference by looking. We put the retaining hook over one of the braids. ![[Linked Image from i47.photobucket.com]](http://i47.photobucket.com/albums/f167/Tinys1938/IMG_0931.jpg)
Posts: 724 |
Tried to find the correct lacing for years…to my knowledge no one has the correct size/configuration….saw a 3/4 wide but no 5/8…I worked with Restoration Specialties (Dave) out of Pa for 3 or 4 years to produce it..he finally gave up…said tooling costs etc. would not justify the demand….I got lucky and found a new roll to exact length, width and configuration in a pile of junk at Hershey in 2013…looks to be NOS….Billu38
Posts: 254 |
I bought a lot of stuff from these guys over the years when I had a '23 Willys-Knight and was always happy with what they sent. I can't vouch for their webbing specifically, but check page 51. It's not wired, mind you, but it is double-beaded. http://www.restorationstuff.com/pdf/RestorationSupplyCompany.pdf
1937 Master DeLuxe Business Coupe 1954 3100 5-Window 1954 Corvette
Posts: 184 |
Thanks for the replies. I will contact the vendors mentioned ... and keep an eye out at swap meets.
