#349977 08/25/15 07:53 AM
Ph1l Offline OP
Can I ask what other members think of the replacement of valve seats so that the 1931 independence can run on modern fuel,before I put the engine back together.also about the main,big end bearings (shells)In the filling station catalogue it talks about a babbiting service does that mean you can't buy big end and main bearings?
Ph1l #349985 08/25/15 09:26 AM
Standard valve seats are OK for the old cars and stellite or hardened seats are not a necessity. Big end and main bearings are babbited so they will need to have the babbit repoured on your rods and bearing shells and then machined to fit your crankshaft. The bearings are shimmed so it may be possible to tighten the bearings by removing shims if not too badly worn. The connecting rods for big end bearings can be converted to accept inserts if desired and that may be an option to consider
Ph1l #349993 08/25/15 10:30 AM
I totally agree. Your car ran on "white gas" (unleaded) when it was new and since you have a low compression engine hardened valve seats are not necessary. Lead additive should not be used either.
m006840 #350005 08/25/15 12:26 PM
Ph1l Offline OP
Great,thanks.Phil.
Ph1l Offline OP
Thanks.Phil.
Ph1l #350026 08/25/15 06:35 PM
Hardened valve seats are a waste of money unless you need to replace the seats because of damage. The exhaust temperature is not even close to high enough to erode the seats even without lead or other additives.
