Posts: 15 |
Can someone help with ID on this Tag.
The car is a 32 3 window coupe.
Job# 32557 Body# B 142 Trim 16 Paint 89 The number for the trim and paint is hard to read( the paint code may be 69)
It should be black with yellow trim. As for the car it is a standard coupe with a single sidemount spare. It was my great grandfathers car. restored in 1978. Just interested to see if it was done back to the original color.
Posts: 3,163 |
Pnt code 69 is from a 31 from what I found. This should give you the details on pnt code 89...Joe
Chevrolet DUCO color Specifications 1932 PASSENGER Combination #89 (Standard Sedan, Coach, Standard Coupe, Standard Five Window Coupe) Hood Black Hood moulding Black Hood moulding outer stripes Ocean Green Hood moulding inner stripe Gold Bronze Wire wheels Ocean Green or Black Body panels Black Body mouldings Black Upper body moulding stripe Ocean Green Lower body moulding outer stripe Ocean Green Lower body moulding inner stripe Gold Bronze Instrument panel Black Instrument panel depression Black
Posts: 15 |
Any paint codes that end in 9 that have yellow as a wheel option?
