#348648 08/04/15 04:48 PM
Can someone help with ID on this Tag.
The car is a 32 3 window coupe.
Job# 32557
Body# B 142
Trim 16
Paint 89
The number for the trim and paint is hard to read( the paint code may be 69)
It should be black with yellow trim. As for the car it is a standard coupe with a single sidemount spare. It was my great grandfathers car. restored in 1978. Just interested to see if it was done back to the original color.
323window #348651 08/04/15 05:49 PM
Pnt code 69 is from a 31 from what I found. This should give you the details on pnt code 89...Joe
Chevrolet DUCO color Specifications 1932 PASSENGER
Combination #89 (Standard Sedan, Coach, Standard Coupe, Standard Five Window Coupe)
Hood Black
Hood moulding Black
Hood moulding outer stripes Ocean Green
Hood moulding inner stripe Gold Bronze
Wire wheels Ocean Green or Black
Body panels Black
Body mouldings Black
Upper body moulding stripe Ocean Green
Lower body moulding
outer stripe Ocean Green
Lower body moulding
Instrument panel Black
Instrument panel depression Black
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
jiaccino #348664 08/04/15 08:38 PM
Any paint codes that end in 9 that have yellow as a wheel option?
323window #348685 08/05/15 02:12 AM
