#347238 07/15/15 02:26 AM
Style Offline OP
Just received vent glass for the coupe from FS .. it is larger and more angular than what I have .. do I have the sedan glass ???
Any help appreciated
https://drive.google.com/file/d/0B1YF3iWTJVBRYm5ZRDdVQ2tUY3c/view?usp=sharing
link is for gdrive pic .. not sure if it will work
Style #347241 07/15/15 03:15 AM
Style Offline OP
note to self .... get required amount of sleep before spending money on the internet..
Convertible not coupe . so all vent glass is the same EXCEPT convertible.....
Ollie
Style #347243 07/15/15 07:25 AM
Depends if you have a "post" club coupe or a BelAir hardtop coupe.The BelAir hard top has the same vent window glass as a convertible and is more angular....the club cope has a more rounded glass.
Chev Nut #347252 07/15/15 10:31 AM
Style Offline OP
Sorry... 1938 master
Style #347259 07/15/15 11:08 AM
It would be far less expensive to just take your original to an auto glass shop & have them use it as a pattern to cut your glass to size.
Tiny #347300 07/16/15 12:42 AM
Style Offline OP
thanks Tiny .. will do that tomorrow .. just have to get one out in 1 piece .. ..
Style #347517 07/19/15 03:29 PM
Style Offline OP
Toughened glass ... needs to be cut to size then sent away for heat treating ... very expensive to do through your local glass shop .. can not cut toughened glass down to size .. ends up in a million little pieces .. bite the bullet .. ordered the correct parts ..
ollie
Style #347521 07/19/15 03:48 PM
Over here it's called tempered glass and a vent glass wouldn't be tempered for the very reason you mention, it breaks too easily & the shards would be dangerous to passengers. Use laminated glass. The only tempered glass in my '38 is the back glass. All other glass is laminated (safety glass) same as the windshield.
