#339768 04/09/15 10:26 PM
Dads52 Offline OP
1952 styleline deluxe 216 standard
1. Is the green stuff still the recommended anti-freeze?
2. What is the best flush.. Still running the original radiator so do not want to use anything too harsh.
Dads52 #339771 04/09/15 10:35 PM
I have been using the green stuff in my cars and have no problems.
All radiator cleaners today are pretty weak and are formulated more to remove slime rather than rust. I have used the more heavy duty type and never had a problem.
Dads52 #339777 04/09/15 11:12 PM
Green antifreeze/coolant or inhibited DI or distilled water are the only coolants that should be used in our old Chevys. Using anything else is asking for trouble.
The "green antifreeze/coolant" is .... ?
Yep....all I use is the "Green Stuff" too!
What brand name ?
Brand name doesn't much matter. There are only a couple of antifreeze manufacturers left in the US despite the number of brand names on the jug.
OK & thanks.
Peak makes an antifreeze called "conventional green" and it is most like the older formulation. I have found it at Advance Auto Parts.
The yellow-green Prestone at Wal-Mart is marketed as "all makes all models" and has a formulation very similar to DexCool. Most of the antifreeze available is similar to this if they say it is good for all cars and extended time/mileage.
Thanks, Dana, good to see you here at VCCA.
