#337787 03/23/15 04:46 PM
oboy Offline OP
Just had the tire wells put in my fenders.they gave me the old wells to use as a pattern but in need a Measurement maybe from the pad holes to the top of the wells.then I can set my old ones in and drill the holes.
Wake up to learn something new everyday.
I measured mine using a stanley with a wide tape. Going from the center of the rivet to the inboard side of the tape, while trying to keep the tape parallel with the opening I get;
top outside rivet 4 7/8, top inside 4". Bottom outside 4 5/8" , inside 4". The other fender was close except the top outside was 4 5/8'. This is ripe for measurement error so better get some more before drilling.
oboy Offline OP
Will do thanks a lot if I get the old one's at those numbers I think I will have the hole for the tire locks real close to where they should be.thanks again!
I should say I only measured the outer most holes from the center of the well, top and bottom. Your well or the pads should give you the other hole location.
