Posts: 509 |
at the top of the page? ![[Linked Image from vccachat.org]](https://vccachat.org/images/header/chatterheader-Jan20-2014.jpg)
Posts: 3,163 |
Ute from Australia....Joe
Posts: 1,294 |
There was a 52 at Flint. It was the only 52 there. Sorry I did not bring my two door sedan.
Posts: 5,906 Likes: 8
Posts: 5,906 Likes: 8 |
Yep, and they're still making them today.... There was speculation a while ago that one of these would be sent to the USA to replace the El Camino.
Posts: 509 |
I like it. Would be nice if they brought them over here.
Image didn't work but you can see the current one on the Holden site.
Thanks, Jim
Posts: 271 |
Apparently you can. Seems like there is a company in Denver Colorado called Lefthandutes.com that imports them and converts them to left hand drive. New Holdens that is.
Posts: 301 |
"Never give up" Louis Chevrolet
Posts: 3,801 Likes: 1
Posts: 3,801 Likes: 1 |
Is the yellow UTE, pictured above, equipped correctly, with that specific rear end panel below the tailgate and no rear bumper?
Posts: 301 |
The yellow Ute is as it came from the factory, the recessed section is hinged at the bottom and opens to access the spare tyre. They never had rear bumpers fitted from the factory though you do see a lot of restored ones fitted with rear bumpers.
The yellow Ute is as it came from the factory, the recessed section is hinged at the bottom and opens to access the spare tyre. They never had rear bumpers fitted from the factory though you do see a lot of restored ones fitted with rear bumpers. Trying to learn more about the Ute. Thanks, Chevrolet6
Thanks for the info. Appreciated.
One more question, is "UTE" an abbreviation for something else ?
Posts: 3,292 |
Should have known that. Thanks.
Hint: The yellow one was on the back cover of the G&D in November 1989. Oh.... check 'em out as much as you can, because I've already got the next header built. I'll install it some time before the Seahawks game on Sunday. And that other team.
Posts: 1,623 |
I believe that is more properly referred to as the "Patriot's Game."
Chevy Guru
I believe that is more properly referred to as the "Patriot's Game."  No, it's the initial "P.S.I. Bowl" We're "pumped up" for this game.
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
I understand that hot air makes the P.S.I. rise. Maybe the "Deflaters" are not full of hot air, but instead just play good cool football. This thread is getting off subject.
Posts: 2,433 |
This thread is getting off subject. ......and look at who took it off subject!!!!
ken48 VCCA 42589
Let's not point fingers particularly when in front of a mirror. Go figure?
Specifically avoided that so I can continue to log in. Win or lose I will celebrate with my other favorite patriot_Sam Adams!
Posts: 2,433 |
If I suddenly vanish.......well, you'll know what happened
ken48 VCCA 42589
Posts: 6 |
The UTE tailgate can be dropped to a vertical position allowing better access to the bed. There are a couple of rubber bumpers that keep it from hitting the body. Installing a bumper would not allow the use of this feature. I have a ute almost identical to the yellow (Sequoia Cream)one. If anyone know who owns it I would appreciate knowing who it is. I suspect it is an Aussie picture. Here is a link to a couple of pictures of mine http://www.cars-on-line.com/BT50-11/BT50-11-bestclassic.html
