#332669 01/26/15 05:25 PM
mark38 Offline OP
Hi trying to set the initial timing on rebuilt 350 with HEI 300hp. I set at TDC but im unable to turn counter clockwise to 12 degrees before TDC. Can I turn motor clock wise and stop at 12 degrees before TDC. Thanks
Wilwood Engineering1955-1957
mark38 #332675 01/26/15 07:04 PM
The distributor is one tooth off.
Chev Nut #332680 01/26/15 07:22 PM
Agree with Gene.Dist is one tooth off. If it was 180 off it wouldn't start or run.
Get it back at TDC #1 on Compression stroke.Drop it back in with rotor pointing to #1 postion on cap.
Good luck. Jim
jimpala70 #374533 08/29/16 03:53 PM
[quote]Agree with Gene.Dist is one tooth off. If it was 180 off it wouldn't start or run.
Good luck. Jim [/quote]
i also agree! it is just a one tooth off. and is will not run if it's 180. try to get it back again. you will eventually succeed on that good luck!
