Posts: 75 |
I broke one of my distributor cap hold down springs. Does anyone have these or have a referral of where to purchase them?
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
I am only aware of used parts. Maybe someone has an extra from a parts distributor.
Posts: 1,213 |
The distributor cap retaining clips are the same as the ones used on a '28 4 cyl with the DELCO-REMY 635-B distributor,as well as the 1933 & 1934 Standard Chev 6's with the small 6 cyl engine,plus a lot of other makes in the '20's using the same distributor cap,eg;Oldsmobile from late '27-'32 etc.The ignition points,rotor button and distributor cap are also the same as used by a '29-'32 Chev cyl.
CJP'S 29
