I broke one of my distributor cap hold down springs. Does anyone have these or have a referral of where to purchase them?
I am only aware of used parts. Maybe someone has an extra from a parts distributor.
The spring clips that hold the distributor cap in place on the distributor body are hard to find.
The distributor cap retaining clips are the same as the ones used on a '28 4 cyl with the DELCO-REMY 635-B distributor,as well as the 1933 & 1934 Standard Chev 6's with the small 6 cyl engine,plus a lot of other makes in the '20's using the same distributor cap,eg;Oldsmobile from late '27-'32 etc.The ignition points,rotor button and distributor cap are also the same as used by a '29-'32 Chev cyl. chevy
CJP'S 29
