Posts: 3,578 |
If you were to have one,what does the ..emergancy brake whistle..do??? chef-
The accessory vacuum emergency brake whistle whistles when the emergency brake is on (car running) to remind you to release the emergency brake. When they are working good.....they are still "Mickey Mouse" because of the vacuum switch that sometimes works and sometimes doesn't. :eek: :eek: :( :( :(
Posts: 3,578 |
Thanks,keith I can sure use this info,although I think the whistle is an option I will put on the back burner.chef-
