Camile Offline OP
I'm trying to get the Ole '37 running right. After I go on a trip for about 30 minutes and stop my trucks seems to be flooding out on me and won't start back. My first thought is the needle is sticking in my carb causing it to flood on me. Does anyone have any other ideas as to what could be causing this? If it is the carb needing to be cleaned is there a good way to clean it without pulling the carb off the engine?
Any input will be appreciated.
The float might be adjusted incorrectly. A slight bit of dirt in the needle valve can also cause flooding.
It would be wise to re-check the carb.
With the carb. on the engine you can carefully remove the pot metal float bowl cover to access the float needle and seat. Check for the correct float level and also check the needle and seat area for dirt. If you have a Viton tipped needle replace it with a metal needle and seat assembly.
Camile Offline OP
I'm relatively new at this and this may seem like a silly question but, how can I determine what is the correct float level?
That information comes in the carb. repair kit that is available from the Filling Station. However, their kits also contain the Viton tipped needle.
By any chance, do you know which carburetor that you have on your car?
www.fillingstation.com
Camile Offline OP
W-1 Carter
The float leve should be 1/2".
Camile Offline OP
Thanks very much
You bet!
Anyone know of a source to buy the metal needle and seat?
Thanks, Don
All of the reproduction carburetor repair kits (many are worthless) now contain the Viton tipped needle and seat. Don't know of any suppliers that sell a metal needle. If you can find a new old stock Carter carburetor repair kit it will contain the metal needle....along with a lot of other stuff like a metering rod and etc.
