#305746 04/14/14 03:39 PM
Good afternoon,
My 32 Chevy heat riser flap that is operated by a cable is rusted and frozen solid. Someone has brazed (flux and bronze rod looks like) an arm to the shaft in the past. Does anyone have some experience working on these old heat risers and, if I need one, will I have to make one or are there replacements somewhere? Or, should I not go to the trouble and just leave it open and not worry about the thing working like it should. Thanks,
Mac
If it's open, pretend you don't have a heat riser cause.....
There was an in-depth discussion on manifold heat risers here on Chevy Chatter sometime back. Too bad that you missed it. Anyway, try doing a search on Chevy Chatter for the discussion because it was very informative and, as I remember, the discussion also included how to make a new heat riser and shaft out of stainless steel.
Will do....
Could not find it.....bummer...
Yep, you missed a good one!!
It's there (somewhere) but the search feature is totally useless.
I tried for over an hour but no luck...Even wen through a ton of the old messages page by page...Chipper advised just to leave it open and not to worry so that is what I will do. I was just trying to get everything working on our old girl. Next is the electroloc and the bushings in the torque tube. Brakes still squeal and stick but I guess this is "normal". Thanks for the response JYD and best always....
Mac
Lee Allen in the VCCA makes a heat riser repair kit for the 1932 manifold:
www.leesparts.webs.com
ph:770-938-0861
He advertises in the G&D also.
Doug
Great information Doug!
Thanks Doug...I am off to get one today.....
Mac
I used Lee's the kit to fix this problem. Just be warned it is a bit of a task to complete the work. Well worth the effort. He uses copper sleeves that require you to drill or enlarge the existing holes. Unless you are machinist you will need to have this done by others. The drill size escapes me now, but our machine shop had to purchase one. It cost me 80 dollars to have this done. This seems simple to do but the tolerance is very tight and must be in line. Hats off to Lee for this fix.
Thanks for the heads up....I am a fabricator and have a lot of machining experience but if it looks too complicated, I can get the work done locally by a friend who is a former NASA machinist....
Mac
Mac,
Doing this project would make a good story to put in the G&D where many would benifit. Just a thought...
Doug
Great idea to write an article for the G&D. Now ....who....should......write.....this....article? OH! How about Doug Zeno.
I'll volunteer to be the proof reader for the article when you get it written.
Agrin devil
Hey Doug,
You should do it since you have a lot more experience than I.....If not, then I could give it a go. Not unlike writing research reports or seminar presentations....Did that for 37 years at Clemson.
Mac
I picked one of the the kits up at hershey but have not installed it on the manifold as of yet. Renovating the house.
Doug
Well, when I get mine, I will disassemble the manifold and give the kit a try taking pictures as I go. If I need to involve a machinist, I will take picture of my friend as he does his work as well. Best,
Mac
