#304841 04/01/14 09:27 PM
How do I hook up the throttle cable to the carburetor on my 1948 Fleetline? The car has been in the family since 1949 and has far has I know the cable has never been hook up. I have had the car since 1977.
There should be a metal "clamp" on the top of the carburetor, to hold the cable and the cable goes vertically down and to the gas pedal linkage...You probably have a cotter pin near the bend where the cable should go...
Can't post a photo...But, a helpful member will...That should clear things up...!
I have trouble posting photos but can send you one via email. I have a carb that is off the car and can send you a very clear photo if you want. Beamer
Chat Region Member
2017 GMC Canyon
This might help
http://s875.photobucket.com/user/Ji...Throtleconection.jpg.html?sort=3&o=1
It is not my own picture. I also borrowed it from another user cant remember the name any more ( for the credits ). stressed
Jianis driving
Thanks, this helps a lot.
Great photo...Shows everything he should need to know...T & C cable placements...
I need this photo also to hook up my throttle cable.
I wasn't so sure it would work that well with as easily my cable would slide back and forth...But, it does...And it really is a "must have" during warm up, etc...
