Posts: 388 |
I have a Canadian built 1948 Chev Stylemaster and it has 3 narrow pinstripes just outside of the hubcap.These wheels are unmolested factory striped wheels. I have noticed most if not all the other factory striped wheels I have seen only have 2. Whats up with that???
The US built 1940-1948 cars had two wide stripes around the hub cp and one wide stripe on the rim...it intersects the valve stem hole.
Posts: 408 Likes: 10
Posts: 408 Likes: 10 |
Here is a picture of an original US built 1941 wheel. ![[Linked Image from i1035.photobucket.com]](http://i1035.photobucket.com/albums/a438/falisedm/IMG_0948a2_zpsdd020c44.jpg)
Posts: 388 |
Thanks minetto, if I can figure out how to post a picture I will post a Canadian pinstriped wheel picture.
Posts: 3,136 |
That takes patience my my friend...But, you said you used tape...How did you get the tape to curve so well...? Thanks for the photo's...Kevin
Posts: 604 |
Posts: 388 |
.But, you said you used tape...How did you get the tape to curve so well...? He used the tape to center wheel on water pump.
Posts: 3,578 |
man you are good!I watched the guy do mine and he followed one strip of tape free hand
